Hi,
Under Sources\Specifics, there are files for Windows and Linux system.
Here is a script to compare them. Put the script under Sources\Specifics folder and run cpSrc.bat, the difference will saved in a cpDiff.txt file.
For GET_INI_FILNAM.f90, the difference is:
There should be a way to work for both OSes, '\\' ?
For GET_MYSTRAN_DIR.f90, the difference is:
I think GET_ENVIRONMENT_VARIABLE (Fortran 2003 and later) and GETENV (backwards compatibility with GNU Fortran 77) could use one to work for both OSes. In new code, programmers should consider the use of the GET_ENVIRONMENT_VARIABLE.
For READ_CL.f90, the difference is:
All are comments. So there should be no difference for this file.
Code:
InputObject
! Gets name (incl path) of the MYSTRAN.INI initialization file. This is the Linux version which uses '/' as a folder...
INIFIL(MYSTRAN_DIR_LEN+1:MYSTRAN_DIR_LEN+2) = '/'
! Gets name (incl path) of the MYSTRAN.INI initialization file. This is the Windows version which uses '\' as a fold...
INIFIL(MYSTRAN_DIR_LEN+1:MYSTRAN_DIR_LEN+2) = '\' For GET_MYSTRAN_DIR.f90, the difference is:
Code:
InputObject
CHARACTER(FILE_NAM_MAXLEN*BYTE), INTENT(OUT) :: MYSTRAN_DIR ! Directory where program executable (and IN...
INTRINSIC :: GET_ENVIRONMENT_VARIABLE
CALL GET_ENVIRONMENT_VARIABLE ( 'MYSTRAN_directory', MYSTRAN_DIR, MYSTRAN_DIR_LEN )
! Gets the environment variable MYSTRAN_DIR that tells Windows where the MYSTRAN executable is located. The user mus...
! environment variable on their computer
CHARACTER(FILE_NAM_MAXLEN*BYTE), INTENT(OUT) :: MYSTRAN_DIR ! Directory where executable (and INI file) ...
INTRINSIC :: GETENV
CALL GETENV ( 'MYSTRAN_directory', MYSTRAN_DIR )
MYSTRAN_DIR_LEN = FILE_NAM_MAXLEN
DO I=FILE_NAM_MAXLEN,1,-1
IF (MYSTRAN_DIR(I:I) /= ' ') THEN
EXIT
ELSE
MYSTRAN_DIR_LEN = MYSTRAN_DIR_LEN - 1
CYCLE
ENDIF
ENDDO I think GET_ENVIRONMENT_VARIABLE (Fortran 2003 and later) and GETENV (backwards compatibility with GNU Fortran 77) could use one to work for both OSes. In new code, programmers should consider the use of the GET_ENVIRONMENT_VARIABLE.
Code:
InputObject
! Begin MIT license text.
! _______________________________________________________________________________________________________
! Copyright 2019 Dr William R Case, Jr (dbcase29@gmail.com)
! Permission is hereby granted, free of charge, to any person obtaining a copy of this software and
! associated documentation files (the "Software"), to deal in the Software without restriction, including
! without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
! copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to
! the following conditions:
! The above copyright notice and this permission notice shall be included in all copies or substantial
! portions of the Software and documentation.
! THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
! OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
! FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
! AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
! LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
! OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
! THE SOFTWARE.
! End MIT license text.
