Trying to add sparse matrix code to LK2/REDUCE_KFF_TO_KAA.f90
Hi,
Trying to use SuperLU sparse solver which is from https://github.com/xiaoyeli/superlu
First: Inputs for SuperLU are:
Code:
            !NROW=n=400
            !NCOL=n=400
            !NNZERO=nnz=1920
            !values
            !rowind - row index
            !colptr - column pointer
Have to map MYSTRAN's I_KOO, J_KOO, KOO to these.
Second: Output for SuperLU is b(i), i=1,n after solving. Need to map this b(i) to what MYSTRAN is called.
Help is appreciated.
Cheers
Cean
The code is like this:
Existing Banded:
Code:
         IF (SOLLIB == 'BANDED  ') THEN                    ! Use LAPACK
            KOO_SDIA   = 0
            EQUIL_KOO  = 'N'
            INFO = 0
            CALL SYM_MAT_DECOMP_LAPACK ( SUBR_NAME, 'KOO', 'O ', NDOFO, NTERM_KOO, I_KOO, J_KOO, KOO, 'Y', KOORAT, EQUIL_KOO,      &
                                         RCONDK, DEB_PRT, EQUED, KOO_SDIA, K_INORM, RCOND, KOO_SCALE_FACS, INFO )
Newly added Sparse:
Code:
        ELSE IF (SOLLIB == 'SPARSE  ') THEN
            ! Add sparse matrix code here to decompose matrix KOO
            !use SuperLU subroutine hbcode1(nrow, ncol, nnzero, values, rowind, colptr)
            !call hbcode1(n, n, nnz, values, rowind, colptr)
            !NROW=n=400
            !NCOL=n=400
            !NNZERO=nnz=1920
            !values
            !rowind - row index
            nrhs = 1
            ldb = n
            do i = 1, n
               b(i) = 1
            enddo
            ! First, factorize the matrix. The factors are stored in *factors* handle.
            iopt = 1
            call c_fortran_dgssv( iopt, n, nnz, nrhs, values, rowind, colptr,
     $                      b, ldb, factors, info )
            if (info .eq. 0) then
               write (*,*) 'Factorization succeeded'
            else
               write(*,*) 'INFO from factorization = ', info
            endif
            ! Second, solve the system using the existing factors.
            iopt = 2
               write (*,*) 'Solve succeeded'
               write (*,*) (b(i), i=1, 10)
            else
               write(*,*) 'INFO from triangular solve = ', info
            endif
            ! Last, free the storage allocated inside SuperLU
            iopt = 3
Here is SuperLU's test data g20.rua
https://github.com/xiaoyeli/superlu/blob...LE/g20.rua
It has 400 rows, 400 columns and 1920 none zero values. The data is arrange as COLPTR, ROWIND and VALUES.
Cean,
Is there a reason you are looking into SuplerLU? Perhaps because it is native Fortran? PaStiX looks to be a great option, but it is coded in C. CalculiX (coded in Fortran) uses PaStiX so there is a way to incorporate it. Here are some papers about solvers. The 2017 paper discusses SuperLU and I made a screenshot of some notable comments.
I also contacted Bill and he is going to look into it.
https://www.mystran.com/docs/Solver_Papers.zip
[Image: SuperLU.jpg]
Yes, just want to try a easy build case.
There could setup a sparse solver switch, like:
If SparseSolver = 'SuperLU' then
else If SparseSolver = 'PaStiX' then
else
   print 'Not supported yet'
endif
Sure, that is a good idea. Have you seen this document? It might help.
https://mystran.com/notes/Sparse_Solver_Notes.pdf
(10-28-2020, 04:07 AM)Admin Wrote: Sure, that is a good idea. Have you seen this document? It might help.
I am following it.
Users browsing this thread: 3 Guest(s)
