FEMAP neutral improvements - numenic - 04-09-2021
Writing a FEMAP neutral parser, I met some some quirks with the file generated by MYSTRAN (v12.1). This thread aims to collect them. Please tell me if I need to split this thread per subject or question!
I'll begin with this a simpleCBAR + CBUSH model. The attached archive provides the following files:
* "bulk_model_TC3.nas": the BULK file
* "mystran_00.NEU": the MYSTRAN output
* "FEMAP_v8.2.neu": the FEMAP v8.2 output
* "FEMAP_v2020-1-0.neu": the FEMAP v2020.1 output
First remark: Block451 is used by both MYSTRAN and FEMAP8.2 to collect results, but is deprecated in later versions in favor of block 1051.
Block451: titles used by MYSTRAN do not match FEMAP titles. This makes harder to write "solver-agnostic" parsers. From the uploaded files, here is the list with mismatch and missing :
That's all for now! thanks for reading and happy MYSTRANning !
Code: | FEMAP vector Title | FEMAP vector ID | MYSTRAN vector Title | MYSTRAN vector ID |
| Total Translation | 1 | RSS translation | 10001 |
| T1 Translation | 2 | T1 translation | 10002 |
| T2 Translation | 3 | T2 translation | 10003 |
| T3 Translation | 4 | T3 translation | 10004 |
| Total Rotation | 5 | RSS rotation | 10005 |
| R1 Rotation | 6 | R1 rotation | 10006 |
| R2 Rotation | 7 | R2 rotation | 10007 |
| R3 Rotation | 8 | R3 rotation | 10008 |
| Total Applied Force | 41 | RSS applied force | 20001 |
| T1 Applied Force | 42 | T1 applied force | 20002 |
| T2 Applied Force | 43 | T2 applied force | 20003 |
| T3 Applied Force | 44 | T3 applied force | 20004 |
| Total Applied Moment | 45 | RSS applied moment | 20005 |
| R1 Applied Moment | 46 | R1 applied moment | 20006 |
| R2 Applied Moment | 47 | R2 applied moment | 20007 |
| R3 Applied Moment | 48 | R3 applied moment | 20008 |
| Total Constraint Force | 51 | RSS SPC force | 30001 |
| T1 Constraint Force | 52 | T1 SPC force | 30002 |
| T2 Constraint Force | 53 | T2 SPC force | 30003 |
| T3 Constraint Force | 54 | T3 SPC force | 30004 |
| Total Constraint Moment | 55 | RSS SPC moment | 30005 |
| R1 Constraint Moment | 56 | R1 SPC moment | 30006 |
| R2 Constraint Moment | 57 | R2 SPC moment | 30007 |
| R3 Constraint Moment | 58 | R3 SPC moment | 30008 |
| Total MultiPoint Force | 151 | na | na |
| T1 MultiPoint Force | 152 | na | na |
| T2 MultiPoint Force | 153 | na | na |
| T3 MultiPoint Force | 154 | na | na |
| Total MultiPoint Moment | 155 | na | na |
| R1 MultiPoint Moment | 156 | na | na |
| R2 MultiPoint Moment | 157 | na | na |
| R3 MultiPoint Moment | 158 | na | na |
| Total Summed GPForce | 161 | na | na |
| T1 Summed GPForce | 162 | na | na |
| T2 Summed GPForce | 163 | na | na |
| T3 Summed GPForce | 164 | na | na |
| Total Summed GPMoment | 165 | na | na |
| R1 Summed GPMoment | 166 | na | na |
| R2 Summed GPMoment | 167 | na | na |
| R3 Summed GPMoment | 168 | na | na |
| Total Applied GPForce | 171 | na | na |
| T1 Applied GPForce | 172 | na | na |
| T2 Applied GPForce | 173 | na | na |
| T3 Applied GPForce | 174 | na | na |
| Total Applied GPMoment | 175 | na | na |
| R1 Applied GPMoment | 176 | na | na |
| R2 Applied GPMoment | 177 | na | na |
| R3 Applied GPMoment | 178 | na | na |
| Total Constraint GPForce | 181 | na | na |
| T1 Constraint GPForce | 182 | na | na |
| T2 Constraint GPForce | 183 | na | na |
| T3 Constraint GPForce | 184 | na | na |
| Total Constraint GPMoment | 185 | na | na |
| R1 Constraint GPMoment | 186 | na | na |
| R2 Constraint GPMoment | 187 | na | na |
| R3 Constraint GPMoment | 188 | na | na |
| Bar EndA Plane1 Moment | 3000 | BAR EndA Plane1 Moment | 50201 |
| Bar EndA Plane2 Moment | 3001 | BAR EndA Plane2 Moment | 50203 |
| Bar EndB Plane1 Moment | 3002 | BAR EndB Plane1 Moment | 50202 |
| Bar EndB Plane2 Moment | 3003 | BAR EndB Plane2 Moment | 50204 |
| Bar EndA Pl1 Shear Force | 3004 | BAR EndA Pl1 Shear Force | 50205 |
| Bar EndA Pl2 Shear Force | 3005 | BAR EndA Pl2 Shear Force | 50207 |
| Bar EndA Axial Force | 3008 | BAR EndA Axial Force | 50209 |
| Bar EndA Torque | 3010 | BAR EndA Torque | 50211 |
| Bar EndA Pt1 Bend Stress | 3075 | BAR EndA Pt1 Comb Stress | 60301 |
| Bar EndA Pt2 Bend Stress | 3076 | BAR EndA Pt2 Comb Stress | 60303 |
| Bar EndA Pt3 Bend Stress | 3077 | BAR EndA Pt3 Comb Stress | 60305 |
| Bar EndA Pt4 Bend Stress | 3078 | BAR EndA Pt4 Comb Stress | 60307 |
| Bar EndB Pt1 Bend Stress | 3083 | BAR EndB Pt1 Comb Stress | 60302 |
| Bar EndB Pt2 Bend Stress | 3084 | BAR EndB Pt2 Comb Stress | 60304 |
| Bar EndB Pt3 Bend Stress | 3085 | BAR EndB Pt3 Comb Stress | 60306 |
| Bar EndB Pt4 Bend Stress | 3086 | BAR EndB Pt4 Comb Stress | 60308 |
| Bar EndA Axial Stress | 3107 | na | na |
| Bar EndA Max Comb Stress | 3109 | BAR EndA Max Stress | 60309 |
| Bar EndA Min Comb Stress | 3110 | BAR EndA Min Stress | 60311 |
| Bar EndB Max Comb Stress | 3111 | BAR EndB Max Stress | 60310 |
| Bar EndB Min Comb Stress | 3112 | BAR EndB Min Stress | 60312 |
| Bar Tension M.S. | 3113 | na | na |
| Bar Compression M.S. | 3114 | na | na |
| Bush X Force | 3774 | na | na |
| Bush Y Force | 3775 | na | na |
| Bush Z Force | 3776 | na | na |
| Bush X Moment | 3777 | na | na |
| Bush Y Moment | 3778 | na | na |
| Bush Z Moment | 3779 | na | na |
| Bush TX Stress | 3780 | na | na |
| Bush TY Stress | 3781 | na | na |
| Bush TZ Stress | 3782 | na | na |
| Bush RX Stress | 3783 | na | na |
| Bush RY Stress | 3784 | na | na |
| Bush RZ Stress | 3785 | na | na |
| Elem C1 T1 GPForce | 85000 | na | na |
| Elem C1 T2 GPForce | 85001 | na | na |
| Elem C1 T3 GPForce | 85002 | na | na |
| Elem C1 R1 GPMoment | 85003 | na | na |
| Elem C1 R2 GPMoment | 85004 | na | na |
| Elem C1 R3 GPMoment | 85005 | na | na |
| Elem C2 T1 GPForce | 85010 | na | na |
| Elem C2 T2 GPForce | 85011 | na | na |
| Elem C2 T3 GPForce | 85012 | na | na |
| Elem C2 R1 GPMoment | 85013 | na | na |
| Elem C2 R2 GPMoment | 85014 | na | na |
| Elem C2 R3 GPMoment | 85015 | na | na |
| na | na | BAR EndB Pl1 Shear Force | 50206 |
| na | na | BAR EndB Pl2 Shear Force | 50208 |
| na | na | BAR EndB Axial Force | 50210 |
| na | na | BAR EndB Torque | 50212 |
RE: FEMAP neutral improvements - ceanwang - 04-11-2021
In stead of writing a new parser, it is more easy to let MYSTRAN output in new FEMAP format. Just set an FEMAP version switch and output in old or new format.
RE: FEMAP neutral improvements - numenic - 04-11-2021
(04-11-2021, 03:50 AM)ceanwang Wrote: In stead of writing a new parser, it is more easy to let MYSTRAN output in new FEMAP format. Just set an FEMAP version switch and output in old or new format.
well, neutral is not so bad to parse (at least compared to f06!). But I didn't get your way ; can you elaborate ? How do I let MYSTRAN change the neutral format, and what is the "new" FEMAP format?
Change MYSTRAN code.
RE: FEMAP neutral improvements - Admin - 04-12-2021
Yeah, if MYSTRAN is outputting old Femap output, the best option is to just fix it on the MYSTAN side. That way is it mutually beneficial.
RE: FEMAP neutral improvements - numenic - 04-12-2021
(04-12-2021, 02:58 AM)Admin Wrote: Yeah, if MYSTRAN is outputting old Femap output, the best option is to just fix it on the MYSTAN side. That way is it mutually beneficial.
sure! and this was the point of the first message list: to ease the modifications on MYSTRAN's side.
RE: FEMAP neutral improvements - ceanwang - 04-16-2021
Are you using Mystran under Windows or Linux? Can you compile the source?
RE: FEMAP neutral improvements - numenic - 04-16-2021
(04-16-2021, 01:14 AM)ceanwang Wrote: Are you using Mystran under Windows or Linux? Can you compile the source?
I'm compiling from sources on Linux
