New User facing issues - Printable Version +- MYSTRAN Forum (https://www.mystran.com/forums) +-- Forum: MYSTRAN (https://www.mystran.com/forums/forumdisplay.php?fid=4) +--- Forum: MYSTRAN (https://www.mystran.com/forums/forumdisplay.php?fid=5) +--- Thread: New User facing issues (/showthread.php?tid=102) |
New User facing issues - avi7 - 12-12-2023 As stated above I'm a very new user. Just installed and started using MYSTRAN since yesterday. I have a very simple static analysis case that I wanted to run as a trial. Here's the error I'm getting: Code: LINK 3 BEGINThe error in .F06 is basically the same: Code: >> LINK 3 BEGINPlease tell me if there's something I need to change. The test case is very simple. RE: New User facing issues - Admin - 12-12-2023 If you can upload the BDF/DAT it will help (may need to rename the extension to txt though). Also, you can try to add PARAM, SOLLIB, BANDED (this will call the banded solver instead of SuperLU). Lastly, you can also get help on the discord server. |
